1 - 7 of 7 Posts
2015 Kia Sorento 2.4 gdi awd
Has anyone put a 2016-2018 2.4 engine in a 2014 Sorento? Having a hard time finding a fair priced replacement. It appears they moved the intake cam sensor and vvt sensors. Will one of these engines work in the older car? I know you would need harness plugs but they appear almost identical long blocks
Did you try taking it to a Kia dealer? Unless there are unusual circumstances, the engine replacement for your vehicle should be covered 100% by Kia (including a paid rental for you to use until the engine replacement is completed).
Unfortunately it’s an early 15 build and not covered. It has 2014 engine. Also it has 190,000 miles.
Sorento 2015 LX 2.4 AWD, Suzuki 2011 SX4 AWD, ( 2000 KIA Sportage, junked)
Has anyone put a 2016-2018 2.4 engine in a 2014 Sorento?...
YOUr avatar shows a 2015 Sorento..are you talking about the same car ? .the replacement of the 2.4 engine covers this engine production ending in March 2014...after which they have supposedly corrected the metal chips problem....
  • Like
Reactions: ron1004
Did you ask Kia to check your vin? That's the only way to know if your vehicle is covered or not.
Discussion Starter #6
Yes. But it’s an early build. Sept of 14
Mine is also a 2015 by VIN but built in May 2014......KIA pushes its next year models early.....
1 - 7 of 7 Posts
