2014 Kia Rio automatic
Update: so I was finally able to get a code pulled from the car and it's a p0705. When I look it up it says it could be a TCM or an ECM or could it be Transmission Range Sensors Any idea what it would cost to fix? When am I able to get these parts from somewhere other than Kia? Would I be able to change as myself or will they require being flashed after they're installed in the car or they just plug and play?
I own a 2014 Kia Rio ex I've had it since brand new at 116,000 km on it now.
As of late when I start the car and put it in to drive the icon on the gauge cluster that shows park drive reverse but once I've shifted from park into drive to start driving it within a minute or so the drive icon disappears from the cluster And when you switch it into manual mode where it normally would show the gear one, two three, four, five six nothing shows up with that either on the dash
The car is basically gutless you can step right on the gas pedal and the RPMs will shoot right up but it takes forever for the speed to pick up there's no rough shifts up or down.
But if I stop the car turn it off then back on the problem fixes itself and doesn't come back again until next time I have it after the car has sat.
Anyone else ever have this problem or have any ideas what this could be ?
No check engine lights on either.
thanks
2013 Rio EX 1.6 hatchback
Sounds 99% like the shifter position switch is bad. It is relatively easy to replace, you have to remove the battery and the battery tray. It's plug and play. Part is a bit less than $50. INSTALL THE OEM one. Buy it new in a hyundai/kia dealer, as it has been redesigned and early ones tend to fail in a lot of kia models.
Looks like we ran into some issues. Please come back and try again later
