Hi all,
So I have the dreaded white smoke on start-up and I want to replace the head gaskets before it becomes bad enough to cause real damage.
Does the rear head come off with the engine in-situ?
Is there any good online guide to this job?
Should I replace anything else while I do the head gaskets? I will replace the valve stem seals while I have the head off. Worth changing the water pump? Timing chain tensioner?
Is there anything equal to/better than OEM gaskets?
Any other suggestions?
Thanks a lot in advance
Discussion Starter #2
Ok thanks. Done. Hopefully shows when I post this message.
Otherwise...
Western Australia
2013 Kia Carnival 3.5l V6
99 Kia Elan 1.8L
Hi all,
I suggest that you PM @DavesSpectra to get his attention, and he can then reply here.
