Sorento 2005
Averagely, turn key 2 times , then car starts, Sometimes, turn key 5 times to start car. Sometimes, turn 1 time to start normally.
if not start, no crank, if start, just smooth.
I have changed starter, battery, Ignition Starter Switch, Neutral Safety Switch / Range Sensor,
and I cleaned a few ground cable connection.
battery is kirkland 121r 550cca
but, the problem is still there.
I wish any profession or experienced handy people could share there ideal about the problem, thank you.
2016 Rio SX Hatch
Check the fuse block that connects to the engine. I just replaced mine on my Rio for a very similar problem. Eventually it will just refuse to start, leaving you stranded.
Sorento 2005
Thanks for your help and instruction! I am going to check fuse box and its connection under hood,
