1 - 7 of 7 Posts
2020 Kia Sorento LX+ Black Line V6 AWD | 2011 Kia Sorento V6 FWD
Hey, so my SUV is spitting out this code, P0024. It has something to do with said timing valve. I've been trying to locate this thing, and have had no luck.
Is there anyone else that has had this issue or know the whereabouts of this timing solenoid?
Thanks!
Sent from my SM-G930W8 using Tapatalk
Hey Beda,
Thanks so much! This is pretty much what I was looking for. I kinda figured the CVVT is stuck or has deposits inside that are preventing it to adjust accordingly.
Ill try and locate them with the picture in the document.
Thanks!
2011 Kia Sorento EX, 3.5L V6
The solenoids are on the top front of the engine. Under the valve covers. I've attached some photos that may clarify what the solenoids are and where they are both located.
This is the front or left bank solenoid plug.
113631
113632
113633
113634
113635
113636
Hopefully that helps you out.
how do i find photos for 2011 kia sorento lx v6 3.5L variable valve timing solenoid exhaust left
I posted a reply with pictures but forgot to reply to your comment since this was an old thread. Hopefully that helps. The left bank is far easier to access than the right, so you are lucky it's that side you need to work on.
Discussion Starter #7
WOW, thank you so much! That is fantastic. I haven't gotten around to fixing it yet. but with those photos that should make it a lot easier. Thank you!
1 - 7 of 7 Posts
