How I fixed it....
I checked the fuse and it was good. Same as the original poster, pushed the button, but no noise/pop. I popped the switch out and while it was still connected I pried the switch apart. The contacts were burnt in the switch. After a little sanding with fine sand paper, the contacts were clean and after re-assembly the door is operating normally again. Will try and post pictures. You pry up on the switch on each side of the gas pump icon....that is where the gripper ears are on the switch holding it in. Also, when you go to put the switch back together, it only goes one way so make sure to line the detents up.
