I have a 2011 Sorento with the airbag light on. The red airbag light in the instrument cluster is on but the yellow passenger airbag off light next to the clock is working as it should. So, i am assuming it is not the sensor in the passenger seat. What else could it be? Thanks
I had the same issue. Is it MT or AT? Anyway, no matter what it is MT or AT you should change the OE part 934902P170 it's the clock spring from the wheel. If you are handy you can change it by yourself if you have the tools. Good luck!
Hi. It seems that the wires inside the clock spring are broken. So if you have a MT or AT Sorento you need to search for 93490 2P170 for MT or 2P370 for AT. If you are a handy person you can change the wheel clock spring by yourself with the proper tools. Good luck!
I also have 2011 Sorento sx had the same warning light on dash checked Kia TSB there was a recall when light came on would be fixed for free. Warranty was extended for 15 yrs 2022.
The warranty extension is for 15 years and unlimited mileage on the clock spring that is added to the oringal new car warranty. If you did not buy the car new, then this extended warranty does not apply. If your vehicle was part of this warranty extension for the clock spring, it is not a recall, you would have gotten a letter from KIA about the warranty extension. "Should you have any questions regarding this warranty extension or if your dealer does not respond to your service request in a timely manor, please contact KIA's Consumer Assistance Center at 1-800-333-4542 (M-F 5am to 6pm PST)"
KIA has issued a repair notice for the airbag light - no cost to consumer to have the dealer check the problem AND fix. I also had the door latches replaced as they are on recall.
207.3K members
