101 - 104 of 104 Posts
Rio Pride JB HB 1.4 G4EE MT 2011
Great to hear that. And nice work on the installation. Good Job!
I'm just visiting from the Hyundai Forum. We're a helpful bunch over there :)
The dealership default answer for just about any fault seems to be to replace the most expensive part in the system, the ECU in this case. Their guess would have paid off this time because that's where the fault was. I doubt a dealership would ever have entertained the idea of using an aftermarket fan controller. Not enough profit in that for them.
Hi @Uno122 & @AUTOSPARK
sorry for additional task or question
I need to know this.
“85” Need to Ground for Low Speed fan Work
Question :
Its Safe ? since 3.5 V came from ECM/ECU
114727
I had some diagram, i dont remember where i get it, just i know its for dual Fan Kia/ hyundai
base from your experience, its also represent this car Rio JB 2 fan ?
114721
2010 Hyundai Accent
After following the pages here, I was confident about solving similar issues with my 2010 Hyundai however these are my reading today, now I'm lost, anyone? Sorry didn't mean to hijack current thread.
Engine Off A/C OFF IGN ON
Rad Fan
85 3.53 v
86 12.3v
87 12.27 v
30 12.4v
IGN OFF
85 1v
86 Ground is erratic
87 6.0v
30 12.4v
Drives : Nissan NV200 Flies : Rans S6ES
And what exactly are the issues your trying to solve?
Rad Fan
85 3.53 v
86 12.3v
87 12.27 v
30 12.4v
The 87 voltage doesn't look right on your car. 12V on that terminal would seen to suggest the switch inside the Cond Fan 1 relay is closed when it shouldn't be. I would monitor the voltage on the 87 terminal of the Rad Fan relay socket, then remove the Cond Fan 1 relay to see if the Rad Fan 87 voltage drops. And listen to see if the Cond Fan relay clicks when you remove it from the fusebox.
If I helped you fix it, why not...
Your support is greatly appreciated
