2005 Kia Rio, 2009 Kia Rio, 1995 Toyotta Corolla, 1997 Chevy Silverado
I found at article on ask.com for changing a Kia Rio gas tank air filter. I guess it was good enough because I was able to change this filter on my Rio today, but I found that the directions were not detailed or completely accurate. I'm posting this for others who may want to change the filter on this model.
BTW, I looked for the filter in the after market, but could not find it so I bought
it from a dealer.
First of all the gas tank air filter is located in the driver's side rear wheel well just behind the gas cover.
To change:
1) Jack up the car and take off the rear driver side wheel.
2) take of the wheel well shield. To do this I had to remove the mud flap (3 screws). There was another plastic 'body screw inside the wheel well. I also removed this. There were also 2 plastic screw on caps. I removed these also and then I was ball to remove the shield.
3) remove the connecting hose that connects the gas tank air hose to the
gas tank air filter. To do this I used pliers to squeeze open to hose clamps and then slide the clamps free. I then removed the connecting hose. Note that you can probably disconnect the connecting hose from just the filter, but I removed it completely to make more room to get at the filter.
4) There are 2 10 mm nuts fastening the air filter to two brackets on the gas hose. Remove these 2 nuts. Note that at this point, the filter is free, but cannot be removed because there is not enough clearance between the gas hose and the wheel well. The next two steps free the gas hose to make room to remove the filter.
5) Open the gas cover and take of the gas cap
6) Remove the 4 screws under the gas cap to loosen the gas hose
7) There is a 10 mm bolt holding a bracket that holds both the gas hose and
the air hose to the under body near the wheel well. Remove this bold an the hoses drop an inch or two.
8) Replace the filter
Now reverse the steps and you are done. Good luck.
it from a dealer.
To change:
