My question has a few parts to it:
[tl;dr No crank with immobilizer warning light. Replace ECU with another paired with key to avoid predatory dealer b.s.?]
First, the biggest issue is my 2009 Rondo (Canadian made 4-cyl) won't crank and shows a solid "key and car" logo light on the cluster. Before this, the car started just fine, drove, and parked. Then minutes later it wouldn't crank. No audible relay clicks or anything.
I took out the battery, charged to full capacity for a few days while waiting for capacitors in ECU to drain, unlatched the two terminal clusters on the ECU, blew out any dust, and reattached. Battery is fully charged with proper voltage and CCA. Battery back in and left like normal for a full day. Still same observations (no start with security key light on dash solid.)
OBD scan tool shows no codes pending or stored.
Every accessible fuse has been tested and confirmed with continuity both under hood and inside by driver's left knee.
I tried repeat turning multiple times to "ignition II" (just before start) and leaving in that position. Exactly 30 seconds later the warning light goes out, but still no start.
Alarm is disarmed with working remote through pressing unlock button as is normal and expected.
Does the key need to be re-learned? If so, how is this done without involving a dealership and incurring great expense? (My local dealership is unable to test key or ECU functions out of the car, and it would still have to be towed in, so $$$ and no guarantee they can fix it...and if so, then a return trip on the tow truck.)
If the ECU is determined faulty, I have a replacement ECU and paired key ready for a reasonable price (I have to confirm it's a Canadian model, though I believe it will be.)
How then would I "transplant" the transponder chip into the plastic of the ignition key I have now? (Or cut off metal key part and solder onto new chip end? Relocate rfid antenna loop coil away from keyway so it doesn't pick up the signal from old key? Just swap out a new ignition lock cylinder?)
Would it work if I get a U.S. ECU that isn't built with chip-in-key security and install that with existing ignition key?
Sorry to bombard you with questions like this, but I have absolutely scoured online resources for hours and have come up with almost nothing.
If you can't personally think of suggestions, but know a Kia guru or at least someone well versed in such issues I described, send them a link so they might weigh in on it.
Thanks again for any constructive and thoughtful feedback that might work toward progressing this troubling issue!
