2008 Sorento LX 4WD: "ESC OFF" & "ABS" Lights & Poor Acceleration
7.7K views 10 replies 2 participants last post by  aquanaut20
The code you have is a CAN (communication ), there is either a poor connection, a bad wire, or corrosion (circuit code)
Unfortunately this is a job for the use of a scope (fortunately they are relatively inexpensive, but have a learning curve)
Took it to an honest mechanic who played with it and occasionally managed to get 4WD on and eliminate the ESC OFF light, but it was inconsistent and wouldn’t stick (I think he was clocking the transfer case). He thought that it was probably a bad new transfer case motor I put in there from ENA on Amazon (grrr). Alternatively, it could be the transfer case itself which would be worth about half of what the car costs. The suggestion from the mechanic was to throw another better transfer case motor in there and not cheap out this time.
I ordered a transfer case motor from Dorman,
Playing with it is not diagnosing, does he not have pro level scanner or a scope..?
Dorman is not noted for good parts..
