2008 Kia Sportage LX 2.0L Manual Transmission
My power windows, power locks, overhead lights, dome light, radio, clock, and tail lights have all lost power. I checked all of the fuses connected to the parts that have gone out and I cannot find any wires that have issues so any ideas or solves would be very welcome.
If everything went at the same time, and nothing chewed through the wires, and BOTH fuse panels show nothing wrong, try thee two things:
  1. Check for a bad ground,
  2. Disconnecting the battery for a few minutes should reset everything. However, the radio may need to be re-initialized.
  • This is MOST important, though: Did you check BOTH of these fuse panels?
113154
Yes
Yes I checked both fuse panels atleast the fuses associated with the instruments and accessories that went out unless their is one in the engine that controls all of them and I not realize it but as far as I can’t tell there was no such fuse in the engine.
