1 - 1 of 1 Posts
OK,
I have blown a timing belt. I have replaced bent valves, cleaned the others, cleaned the head, put the head back on (in all that that entails).
Now I am putting the two cams back in and there are some caps with two bolts that hold the cams in place(think ive seen them referred to as rod caps? maybe cam bushings?) well, whatever they are, anyone know the required torque for these bolts and if there is a specific sequence? Seems i have found specs on everything but these...
Want to be clear, not asking about the head bolts. I am asking about the bolts that hold the pieces that hold the cams in place, the chain tensioner, all that moving stuff in the engine, etc...
1 - 1 of 1 Posts
