Can someone please help me in checking the front seat belt electrical connections. Airbag light comes on, when reset it stays off for 1 - 2 months and then comes back on. Got a low voltage reading and a seatbelt tentioner code. I was told the tentioner is working ok, suggested the connections. How do I take off the scuff plate to get to the seat belt? Thank you!
hi rcksmpsn
have you looked at the electrical conections under the seats i have this problem not long ago and the airbag light went out
i hope it helps
hi rckmpspn
remove the plastic tray under the passager seat you have a yellow wire with yellow conector it may have come lose.and i think theirs under the driver's seat also
i hope it helps
I located the boxes and had problems opening them. I got them to open partially and worked on the wires, nothing really loose that I could see, but I tried to make sure that they were seated and secure. If I solved the problem, would the light go out or will it have to be reset? Thanks!!
