1 - 8 of 8 Posts
Can someone please help me in checking the front seat belt electrical connections. Airbag light comes on, when reset it stays off for 1 - 2 months and then comes back on. Got a low voltage reading and a seatbelt tentioner code. I was told the tentioner is working ok, suggested the connections. How do I take off the scuff plate to get to the seat belt? Thank you! :)
1995 kia sportage 2.0 16v manual.. 2005 05 kia sportage 4x4 xs petrol
hi rcksmpsn
have you looked at the electrical conections under the seats i have this problem not long ago and the airbag light went out
i hope it helps
Hi dap310, thanks for the reply! Exactly what am I looking for under the seat. There is a box, but what to check?
hi rckmpspn
remove the plastic tray under the passager seat you have a yellow wire with yellow conector it may have come lose.and i think theirs under the driver's seat also
i hope it helps
Discussion Starter #6
hi, dap310
I located the boxes and had problems opening them. I got them to open partially and worked on the wires, nothing really loose that I could see, but I tried to make sure that they were seated and secure. If I solved the problem, would the light go out or will it have to be reset? Thanks!!
hi rcksmpsm
if the airbag lightgoes out happy days but the fault will be still in the memory so a reset will be the answer.
1 - 8 of 8 Posts
