I have a 2007 2.4L Optima with 72,000 miles. All I have ever done was change the oil and brake pads. My Transmission fluid is a little brown, not really to bad still has a pink hue to it. I notice when I change the oil there is a drain plug on the bottom of the transmission. Seems like an easy thing to drain and refill
When does the maintenance schedule say change the Trans fluid?
Does the transmission have a filter ?
Would you change it or let it go, I've not had any problems with the transmission or car at all.
