I have a 2007 Kia Spectra Ex with 86k miles on it. I just had the brakes, full throttle body, spark plugs, transmission fluid and filter, and oil changed/cleaned/replaced. The radiator was recently replaced after a minor accident.
I noticed that when I accelerate from a stopped position the tachometer will slip very slightly and then speed up just fine. The car holds speeds fine and I did not have any problems with a month ago. I took it to two different mechanics who test drove it and read the codes and they said that everything was fine, but it still bugs me.
So I wanted to know, is this a common thing with the 2007 spectra? Or should It take it back and have them check again? Could a dirty idle air valve be the culprit?
