Hello all!
The strangest thing has been happening to my Kia recently. The first thing started as a small squealing noise from the engine compartment that only last 3-4 seconds and would happen ever 30-40 seconds. The really weird thing is when this would happen, all of the interior lights and headlights would noticeably dim for that 3-4 seconds with the squeal.
Than stopped after 2-3 days and hasn't came back. Then about a week later my brake light switch went out, causing a service engine light. Replaced that, engine light out all is well. Until...
Now what's happening is every so often, while driving normally, the ABS, ESC OFF and Brake Lights on the dashboard will blink on and off AS WELL AS the Clock / Temp in the upper console (on the roof) Almost as if Im turning the key on and off. This happened for a period of anywhere between 5-15 seconds. What I find weird is that those are the only lights that are affected. The Clock on the Upper Front of the dash, as well as the radio and interior lights do not flash.
The battery was replaced 6 months ago and was tested by Autozone as being good as well as the alternator showed no signs of problems.
So now what?
So now what?
