You need to diagnose not change parts or a mechanic that guesses, that just cost you $$$
You indicate a miss fire on #2, that could be spark, fuel and mechanical..
Hi leo,You need to diagnose not change parts or a mechanic that guesses, that just cost you $$$
Those valve cover gaskets leak quite often. The front leak tends to destroy alternators. It won’t solve your misfire problem but it wasn’t a waste of money.Hi all,
Hoping someone can help.
I'm having issues with my car, its only been with me for a month. Its got less than 200,000kms on it.
Recently while driving, the car started misfiring and trouble codes P0300 and P0302 came up.
I tried checking it myself by replacing the spark plugs and moving the injectors and coils around.
The P0300 and P0302 code stayed on after swapping coils, injectors and plugs around.
I replaced the fuel pump and no change.
Brought it to a mechanic nearby who blamed the leaking valve covers and replaced it.
After replacement, misfire stayed and codes are still the same.
We have plans this Easter but looks like we wont be going.
Thinking about bringing it to Kia due to Easter coming up, they are fully booked until mid April.
Any suggestions or ideas would help.
Thanks in advance.
Did you clear the codes before swapping? Just double checking the obvious.Hi leo,
yes, that is correct. as for my previous investigation stated above, i replaced the plugs as im sure it hasnt been done before and swapped the coils around. that told me that there is nothing wrong with the coils and plugs and injectors. i also tested coil number 2 with a spark plug installed to visually check for spark and there was.
Today, i tried to run new wiring for the injector and coil up to the main wiring harness going to the battery side. this still did not fix the issue.
i brought it to the mechanic as i was expecting a more intensive fault finding they did perform a compression test and it showed that all cylinders were close to each other. they had the car for 3 days until they gave up.
I'm planning to bring it to Kia as they probably know more about it than any other mechanic or me.
any other suggestions are welcome.
Thanks Leo. Ive checked the car over for blown fuses and cabling that could have been melted or shorting. so far nothing so its booked with Kia and wont be looked at til the 19th of April.You need to get a scope on the vehicle, and drill down on the issue.
A diagnostician would be preferable over a mechanic..
Yes, I knew it wont. It was leaking quite badly so i just had it replaced to save the alternator. Cant DIY anything at the moment because of a broken hand. It was also a good test for that workshop, atleast I know I wont be coming back there in case of emergencies.Those valve cover gaskets leak quite often. The front leak tends to destroy alternators. It won’t solve your misfire problem but it wasn’t a waste of money.
Yep, cleared the codes before hand and the battery removed. Still no luck.Did you clear the codes before swapping? Just double checking the obvious.
Ive gone and booked it with a Kia dealership, I will ask them to check that as well. Hopefully if there are any ECU updates, they can perform that as well.Have your mechanic do a relative compression test with a scope. You may have a valve hanging open on the offending cylinder.
Short drives, not long enough to burn of any moisure contamination and too long between oil changes.The inside has some sludge and varnish. This has only got 190,000kms and the service history is on point. What could cause the sludge?
What makes you so confident that the service history is good, considering you've not had it long?The inside has some sludge and varnish. This has only got 190,000kms and the service history is on point. What could cause the sludge?
That would be a wise move seeing as the "mechanic" you've been using lacks diagnostic skills.Thinking about bringing it to Kia due to Easter coming up, they are fully booked until mid April.
If you suspect your vehicle falls into this camp, leave well enough alone and skip the engine flush.
It’s probably not worth trying to revive an engine in such poor condition without first fixing the bad seals or other defects.
In effect, you’re choosing your problem: either sludge and deposits robbing performance or, if you clean the engine, the seals showing their true condition.
Yeah, im actually thinking i shouldnt trust the service history by the dealer as i have experienced it with a company car where they tell you they did all those things but in reality, they didnt.What makes you so confident that the service history is good, considering you've not had it long?
Sludge with varnish is an indication that low grade oil was used and extended operation between oil changes.
If it was sludge only it could be a result of the engine never reaching the correct operating temperature.
There's high risks doing an engine flush, but you might make the call on doing so based on "what you got to lose".
If a flush chemical is used you would need to do very frequent oil and oil filter changes until its clean.
Engine Flush: Is It Good or Bad for Your Engine? (Plus See How To Do It)
An engine flush will improve engine performance in most cases, but you may want to skip it with old, high-mileage engines. Find out more here.blog.amsoil.com
Hi Leo,Done replace the harness until proven faulty.. Do you have the experience and equipment to start tests at the ECU
Hopefully thats the case. When i tested the OCV, it was moving freely. The only code im getting is a conistent P0300 and P0302. The mechanic did and they said its all close together. I dont have a compression tester with me. I might invest one.The missing filter may have been removed to fix the problem of the filter falling apart and lodging in the valve, the fact it is missing is a minor concern, but would not cause misfiring only. If the valve had a problem you would gat a CVVT correlation code as well as misfire on the whole bank.
Have you checked the compression on that bank?
