I have a transmission ATF level question for a 2006 kia spectra5. The dipstick on the automatic transmission indicated a severe over fill condition on ATF fluid (probably 2 quarts+ over filled) before I attempted to drain and refill. The fluid was due for a change so I drained it by removing the large (24mm) drain plug in the bottom of the transmission pan and the small (12MM) drain plug at the bottom of the diff. Total fluid drained was approximately 5 quarts. Refilling with 4 quarts still indicates a severe over fill condition on the dip stick when hot after driving about 10 miles. This car was bought used and I am beginning to think someone swapped the dipstick with the wrong one. The dipstick appears long enough to extend to within 1/4" or less of the bottom of the transmission pan. The cold low fluid mark on the dipstick is only about 1/4" from the end of the stick and the cold high mark is about 1/8" above this. If this is right, the transmission would only have approximately 1/2" of fluid or less in the transmission when full. I cannot believe this is right. The book ATF fluid quantities indicate it should take 6.5 quarts. The dipstick levels do not seem to be even close to this as with 4 quarts installed after draining it indicates over 1 quart overfilled. What should be the length of the dipstick and/ how high up in the transmission case should the fluid be when hot? Levels were checked when hot on level ground. The engine oil also indicated an overfilled condition by about 1 quart when parked on level ground.
