Hello All, After 120,000 miles I am about to replace the factory spark plugs on my 2006 Sorento. Any recommendations on which plugs would be best? Thanks for any advice in advance.
You did not tell us if those are original or not. That being said go back in with OEM. They should be NGK or Champion. They worked good for 60-120 thousand. I use the Iridium style.
+1 I would stick with the OEM plugs also use the recommended anti-size check with parts dept on which to use and dialectic grease for the plug boots and torque to proper specifications .
