Hello, I have a 2006 Sedona EX. It has a powered trunk. The trunk operates fine and has power, except it no longer has a warning beep when I open or close the trunk. Is there a fuse for this or could it be something else? I found the fuse panel in the trunk but didn't see anything that looked like it would fix the non-beeping issue.
06 Grand Carnival
There is a seperate chime, by the look of the picture it might be inside the tailgate. Will need to check wires and conections and test beeper.
Cheers
Brian
