1 - 8 of 8 Posts
06 Spectra EX
Hey guys im new to the forums. I recently replaced my front pads on my spectra and now im getting like 15miles to the gallon, about 220miles to the full tank. I was getting 300/tank until i changed them. I have the right pads for sure but i am getting a rubbing sound when the brakes are pressed lightly when at low speeds, like barely moving speeds. I had a little trouble compressing the piston on one of the calipers but i dont think that the rubbing is coming from that caliper. Could it be the rear brakes locked up? Maybe the right side, even though i had no problems compressing the right side caliper? My car only has 60,000miles. Any suggestions would be greatly appreciated.
The pistons in the rear calipers have to be screwed in, for lack of a better term. If you look at the rear pistons, you will notice 4 small notches round the lip of the piston. You can buy a cheap tool to turn the pistons in or you can use a screwdriver. You cannot squeeze the rear pistons in like the front.
06 Spectra EX
I never replaced my rear pads should I still twist back the pistons on the rears anyway? I have the tool and all.
My bad, I thought you had done the rears and possibly binding up. I have seen pistons freeze up so bad that they wore the rotor down to nothing. Take your car for a short spin and then check each wheel for heat to eliminate a stuck piston.
06 Spectra EX
ill try that out. thanks. hopefully i figure it out soon i dont want to take it to the dealership here because they charge $500 for the 60,000mile service and another $500 for the timing belt which i also need to replace soon. :huh: ill check all the calipers this friday and if they are still acting up then im SOL for the moment.
06 Spectra EX
figured out that its my caliper slide pins. i greased em up and its alot better than it was but still not 300miles to the tank. ill replace spark plugs and maybe that will help too.
Check out the "sticky" at the top of the Cerato/Shuma/Spectra section of these forums about an 08 Sx timing belt... If $20~$30 and about 4 hrs time is worth $500 take it to the dealer otherwise do it yourself... Get an AC belt also while your at it... Parts get at rockauto.com quick delivery,good prices, and ALSO a sponsor of these forums...They will also work out ANY problems with your orders.
After spark plugs check your air filter. Then disconnect battery for 5 minutes and then reconnect battery. Go for a drive like you normally would and the ECU will then readjust itself while running with new plugs and a clean filter. The ECU will then alter its map according to the new driving conditions.
1 - 8 of 8 Posts
