2006 kia Sorento
Hi guys,
I have a 2006 kia Sorento and I'm looking for a diagram or information on where the green sensor wire for the crankshaft position sensor(1.5v) connects to the ecu. I've got a short causing low voltage and a crank/ no start condition. Need to test at the ecu but there's several green wires. Thanks in advance.
99 Kia Elan 1.8L, 17 Ford Edge Sport 2.7L V6, 15 Mustang 3.7L V6, 2013 BMW K1600 GTL
Hi guys,
I'm looking for a diagram or information on where the green sensor wire for the crankshaft position sensor(1.5v) connects to the ecu. I've got a short causing low voltage and a crank/ no start condition. Need to test at the ecu but there several green wires. Thanks in advance.
Using the below link, please add location and vehicle (year & model) to your Profile/Account Details
eg.
USA
Kia Forum
Forum Rules
2006 kia Sorento
There shoul;d be a connector between the engine harness and the main harness. I would think best to start your checks there than at the ecu. (It would be in the engine bay).
There is a set of connectors on the passenger side near the firewall. I can test there but I need to know which green wire on which connecter is for the crankshaft position sensor.
