2005 Spectra 4 cyl.
I have changed the alt/wp, and alt/power steering belt 4 times. It will not stop squealing. It is very loud squeak. I looked at both belts. Looks like the belt is slipping on the power steering pulley. Pulley sort of looks like it is slipping. I read when you change pump, the fluid needs to have air vacuumed out. How do I check pump to see if that is what it is? Thank you. Mike
Drain out the OLD power steering fluid and refill with fresh. It uses the same auto trans fluid for steering system. I used MOPAR ATF+4 in my daughters 09 spectra and it's been about 6 months now without a single squeak.
