Hey Guy's your life savers here I just bought a 05 sedona 109000 mi probley needs timming belts can you be so kind to give me a ball park price I'll do some shoping around here two( lower alabama) no other problems great van.thanks partners,[email protected]
Welcome to the forum! Prices will most likely vary greatly depending where you go. Dealership price I believe would be around $600 for parts and labor. Be sure to replace the belt and the tensioner.
I dont know were you might be located but here in Washington State I just paid $685 and they did the belt, tensioners and also the water pump since its right there behind the belt. If you need it I would recommend doing both together.
Those prices are cheap. I went to the dealership and they quoted around $1,200 to do the timing belt and pulleys, they didn't mention anything about changing the water pump.
Oil in Water...but wait head gasket only just done & head had crack test & skim
Guys,
Help needed.
Bought a 02 2.9CRDI Auto in September 09 @ 100k miles at 104k and 1 week out of warranty a heater hose blew & I found that the water system was contaminated with oil, took it to our local garage...
Key wont come out-( car starts fine.) Key comes out fine when battery disconnected or the driver side fuse ACC OR K/Lock Key Interlock Solenoid fuse are removed. I have removed just the Interlock Solenoid Fuse and the key comes out fine.
hi everyone, i just bought Sedana 05 EX. everything is fine, but chime sound will not stop while the vehicle is rolling (no warning light showing on instrument panel) to indicate the prob. i asked the prevouse owner, but he doesnt know the reason.
i really appreciate any hint
2007 Kia Sedona. My ESC light is coming on when i accelerate to get up to speed on hills. When I shut off the car and it is restarted the light is off. I have seen on utube where this is possibly related to the throttle position sensor. I do not have the loss of power they are experiencing. Is...
