Driver's door does not appear to unlock all the way. Door won't open so I am unable to remove the door panel all the way. It appears that the cable for the handle is stretched out. The key and automatic lock does not work. Have also tried to open the door with both inside and outside handle at the same time. Has anyone else encountered this issue and if so any helpful advise would be greatly appreciated.
2005 Kia Sedona EX
I also have the same problem. The door handle was just replaced in my 2005 sedona. I pull the handle and the door does not open. I have to open from outside. I need help from someone on the problem.
