There are two tabs with rubber attached to them, which are located on the outside of the glove box. One tab is located on the left side, and the other tab is located on the right side. When the glove box is open, these two tabs rest on the dashboard vinyl to prevent the glove box from falling out.
To remove the glove box:
1. Grab the left side of the box and pull on it to the right. This will move the left tab away from the dashboard vinyl, which will allow the left side of the box to slide out. Now, the box will hang from the right tab.
2. Pull on the box to the left. This will move the right tab away from the vinyl, which will allow the box to fall out.
