1 - 1 of 1 Posts
2004 Sorento ES
I recently purchased a 2004 Sorento es. Today it would not crank (no noise) but the power on everything worked. I used the auto start and it started I put the key in turned it to on and drove home. I turned the key off and it kept running. I used the auto start to turn it off. When the key is turned to the on position all everything lights up normal but it won’t crank, then turn it off and everything shuts down. With the Astro start it will start fine and die if I touch the break without the key in (normal) but once I start it and turn the key to the on position I can’t turn the engine off with the key. I can completely remove it and it runs. I’m thinking a linkage came disconnected or they key cylinder is bad. Any thoughts? Thanks.
1 - 1 of 1 Posts
