hey I have a 04 rio with no tach, would anybody know if there is a rev limiter. if anyone has a rio with a tach and a 5-speed could you tell me what 6 grand in second and third gear are?? thanks for the help. tj
04 Kia Rio (my babe)
Um I have the same thing an 04 kia rio spd as well. dont have a tach but i dont think it has a rev limiter cuz iv buried the speedo a few times on a track and it just pinges. not shut off or anything. IM in the process of puting a tach and i have no clue were the wire is for it.
OK to install a tach in 03-05 kia rios, pull out the cluster and the center plug contains a brown wire with a red strip. Tap your rpm sensor wire from your aftermarket tach into that wire the put your cluster back in. Its the 4th wire from the the right before you unplug it. To prove it, look behind and look were the center plug goes in and count over from the right to the 4th and you will see a metal lead that is only about an inch long and goes nowhere. thats it.
