I have a transmission leak on the shifter linkage on the 5 speed transmission, its the linkage seal, I order the part whole $13.00 worth , but not sure If i need to remove transmisision to replace that or not, I removed shifter linkage but not sure if the end of the linkage spins apart or if it needs to be disassemble from the inside out. Any help is appreciated.
Thanks in advance
Discussion Starter · #2 ·
I found a service manual online that i purchased, by looking at the manual it looks like it should come apart without removing the transmission, Can someone verify that this is correct. I dont want to try forcing the piece off and break it.
thanks Trevor
Ford Escort '01, Kia RIO '03
Nothing beats a hard copy book, especially if one wishes to take it to the shop or elsewhere.
Not worried about the cost of the book I just wnat the darn thing fixed, I read a post about the free manual however, when i tried registering it came back with errors of site being down , so I just purchased it.
Again any help is appreciated on getting this repaired
Thanks in advance
Trevor
