I have a 2004 kia spectra. About 2 weeks ago, the tranny started winding out when accelerating. I would have to take my foot off gas pedal for a second then when I put it back on it would transition to the next gear. When it started it was only once in a while. Well today I went to drive it, put it in R and stepped on gas and it would not move at first. I did it again and it backed up out of the driveway fine, then put in D and same thing. While driving it shifts gears hard and makes that winding noise when trying to switch gears. I opened the hood to check tranny fluid and I noticed a leak right away! It is leaking from the hood of the car, it's all over the bolts and what ever else is around it on the same side as the dip stick. I checked dip stick and it doesn't look all that low. Could it be something simple or is the kiss of death for the tranny? It seems like a hose leak to me but I am not a mechanic. My husband is handy with car repairs and does most of the repairs himself. I just thought I would get a jump on it for him for when he gets home from work to save time.
Also, on a dodge Durango we used to have we had a similar problem. My husband put "gunk" transfusion in the tranny and it solved the problem. Can I use something like that in a kia? I have read that you're only supposed to use kiaIII tranny fluid. This is a universal fluid used in most autos.
Thank you in advance for your help
