2004 kia rio 5 speed manual transmission. 94,000 miles on the car approximately. New timing belt 20,000 miles ago.
I'm located near Corvallis, OR
Codes:
P0030
P0036
P1166
Parts that have been changed:
Valve cover gasket (oil was leaking down in to spark plug tubes)
Mass air flow
Spark plugs
Spark plug wires
Drive ability:
hesitates in first and second gear. must rev it up pretty good to get it to go. Loss of power going up hills. at a stop light in neutral it holds a higher idle and can try to pop the throttle to get it to come down but stays up there so maybe dirty throttle body or IAC.
was going to change the fuel filter but it does not have one. I've read around on the forums and found that some are like this.
fuel mileage driving to and from work which is short commute (less than 5 miles) and driving locally around town and very lil in the country has dropped from 36 to 31 mpg. not a huge drop but noticeable.
its not my car so maybe i should go for extended drive to see.
Ideas?
Thanks
Codes:
P0030
P0036
P1166
Mass air flow
Spark plugs
Spark plug wires
Drive ability:
Ideas?
Thanks
