does anyone know how to adjust the pulley tensioner for the drive belt? all the information that i could dig up online and in the manual is too general. the problem is because the space is so tight i first need to know what size the adjustment bolt is, there is not enough room for my hand to get to the side of the pulley for me to slip a socket to test what size i need. also i need to know how to get a wrench on this bolt. i cannot seem to figure out how this is done
how do you get access to the adjustment bolt?
what size is the adjustment bolt?
what type of wrench did you use?
if you used a socket wrench, was it a 1/4 inch drive?
did you use a shallow socket?
to anyone that has done this on this car before, what is the procedure? thanks
