Kia and its Sedona, not a good choice for me. I have a Kia Sedona LX 2003 that was purchased in April of 2003. The van is 26 months old and has 93,966 miles of which 60% are highway miles. I use the van for my business in sales and some light hauling of goods.
Like many people car shopping in today’s climate two key components came to mind, economics and quality. Point one was economics. Although the initial cost to purchase the Sedona was economical, as compared to other like choices and its $19,000 price tag, it has become an endless money pit to say the least and a huge headache. I think I could have purchased a Mercedes that would have cost more up front, but would cost less to drive over the long haul. Point two was quality. The quality seemed exist through Kia’s good advertising, good rating in crash tests and its 100,000 mile as advertised warranty. With all the issues I have incurred with the van and dealer troubles (all listed below) it’s fair to say quality is not the top priority. The 100,000 mile warranty is a great selling point but that’s about it. If one does not read the fine print and abide by the strict guidelines, as to scheduled services, the warranty is null and void regarding those areas or parts. Don't be fooled by the bumper to bumper coverage because it does not exsist. Example, the timing belt must be changed at 60,000 miles, as told by the service man after the fact of having this problem, at Folger Kia in Charlotte, NC. If it is not changed then all related issues due to not changing the timing belt will not be covered by the warranty. Never was I informed by the dealer or Kia of such service prior to having this problem. I did have the van serviced at 61,000 for oil and tires and nothing was mentioned about the timing belt change at that point. In comparison to my Mitsubishi Montero Limited and a Chevy Silverado, I have never had any problems with warranty work, or non-work, from either of them. No questions asked "we'll fix it" and it will be covered. Both warranties were plain, simple and straight forward. Any question I had or work that needed to be done, concerning warranty work, was done without question and without cost to me.
One thing to keep in mind is regular service work. The cost of service work and other “mandatory” service work is outrageous. I guess they try to get the money out of you in the service fees instead of the purchase price. I’m not sure if it’s just this area or if it’s the dealers that the costs seem to be high. Just a regular oil change, lubrication and tire rotation is $46.00 with the Kia. My Mitsubishi Montero Limited, the same service is only $25.00. To date I have spent $2692 on work that should have fallen under the 100,000 mile warranty which was not covered by Kia. This excludes regular oil changes, tire rotations, lubrications and such. The $2692 comes only from work, that in my opinion, should have been covered by the warranty. These costs also exclude the $3600 estimate for a new catalytic converter and related parts that the dealer says needs to be replaced. I have refused to install thses parts. I will run the lemon until it expires (blows up, which should not take too long the way it’s going).
Issues listed below:
1.Driver seat armrest loose, would not stay in the up position.Warranty covered. 23,541 miles.
2.Rear part of headliner came unglued. Warranty covered. 31,996 miles.
3.Defrost button did not work. Warranty covered. 31,996 miles.
4.Chiming sound when making right turns. Warranty did not cover. 75,211 miles.
5.Engine light on. Evaporation leak. Warranty did not cover. 75,211 miles.
6.Engine light on. Mass air flow sensor low input failure, replace. Warranty did not cover. Later found that part was not needed to fix problem. Also found this not to be the cause for the engine light being on. Timing belt was the issue. 80,067 miles. Warranty did not cover.
7.Vehicle cut off while driving, timing belt jumped off, starter seize, further damage may result in engine. Warranty did not cover. 82,477 miles.
8.Timing belt off again. Later found that part was not installed correctly. 82,477 miles.
9.Engine light on. Mass air flow sensor shorted. Warranty did not cover. 82,477 miles.
10.Began to idol really rough. Needs new catalytic converter and related parts, $3600 estimated. Warranty would not cover. 93,966 miles.
11.Accelerator cable replaced. Warranty covered. 93,966 miles.
12.Air condition will not turn on, have to play with switch for it to work.
13.Continuous clicking noise coming from front wheel. Dealers have not been able to figure what problem is coming from.
14.Lug nut left off during regular service. Replaced and charged for lug nut.
I have used two different dealers for the above mentioned service work. Folger Kia in Charlotte, NC and Paramount Kia in Mooresville, NC. Folger Kia was the dealer which installed the timing belt incorrectly and replaced the mass air flow sensor which did not need replacing. These problems were found by the service department at Paramount Kia and they are the ones which reinstalled the timing belt correctly and said the mass air flow sensor did not need to be replaced. Paramount has worked with me as much as possible.
When the timing belt jumped off (issue 7 above) Folger Kia did the initial work. Folger called me and stated that belt had come off and there might be further damage to the engine. But, before any more work was to be done I would have to pay for what they had done so far. Discussed by Folger’s attitude I had the van toad to Paramount Kia. Paramount did charge back the “wrong” work done by Folger to Folger and left me to pay the balance for what Paramount had done to get the van running. Folger was the dealer where the van was purchased.
In summation the Sedona has cost me roughly an extra $104 per month just to drive the thing. This does not include the estimated $3600 for a new catalytic converter and related parts which would increase the monthly total to $242. If you include the $3600 and the $2692, total of $6292 for work done, or needed to be done to this 26 month old van, the total cost just to keep it running would come to 33% of the total cost paid to buy the Sedona in roughly two years time. All for work that should have been covered by the totally miss leading 100,000 mile warranty as it is currently advertised. These costs exclude fuel, oil changes, lubrication, tire rotations and any regular maintenance. I will not purchase another Kia nor will I offer any good remarks to anyone that would ask me about my Kia.
