Everything is hooked up correctly and the ems fuse does not blow when the faceplate is off of the deck. i can drive forever....until i put the faceplate on the deck moments after putting the faceplate back on the deck the Ems fuse blows again until i remove the faceplate to my deck everything has been checked, nothing shorting out all wires are covered everything seems to be fine however the fact that when replacing the faceplate onto the deck the 10 amp Ems fuse blows again....i have no idea what this can be battery is good alternator is good just have no clues as to what is going on....
Just a guess here, but it sounds as if you have a wire grounding out somewhere. Check all the wiring to make sure there is no bare wire showing which could arc out. It may be that your headunit is not powered up when the faceplate is off.
