Im new to forum, and would really appreciate some help from the more experienced members on here. So here goes....
put some diesel in and pulled out garage, then it cut out. managed to start it after half hour with jump leads, but it only went about 20m. had to have it recovered home.
My brother put his computer on and got code U0006. Changed fuel filter, crank shaft sensor. He checked fuel pump and relay/fuse. Checked sender unit in tank. He says the tank was fine and no lining issues. All this and it wont even start now. Im at wits end, any help greatly appreciated
Diesel Pro
Have you checked the 'leak back' hoses from injectors which can deteriorate and allow air into system (Had that problem on a Vauxhall Frontera), but can't see why that would happen so quickly after a putting fuel in. Silly suggestion .... check the sales receipt for fuel. Was it really diesel you put in? It happens!
