02 spectra non abs. Had low pedal felt like bad master replaced with new after market. Bench bled and all lines as well. No cure, worse if anything. Pulled rear drums found shoes marginal and a seeping cylinder, replaced all and re-bled all, adjusted park brake, test drove applied park brake numerous times. No improvement from before repair. I know it's not the booster because one would have hard pedal all the time. It does seem to harden a little with pumping. Also the proportioning valve was replaced and bled with the whole system. I am a mechanic anicall inclined but this has defied my experience. Rear drums are at 200 mm with in specs... Any advice welcomed....
