Hello! Sorry for the long thread, I wanted to be thorough and clear.
I own a 2002 KIA Rio with 54,417 miles. As I was driving around, I noticed my car was acting strange. It started with the radio volume fluctuating between really loud and really quiet. After idling at a drive thru bank for maybe 1/2 an hour, I drove to another errand when the car decelerated then suddenly died/stalled.
Here are my findings:
- The car did NOT throw a CEL before this happened.
- The fuel pump will not prime nor will the starter engage.
- The car was at normal operating temperature.
- The battery was tested and found to be fine and the car refused to jump start.
- My horn, radio and door open light are dead.
- The dashboard lights that come on are the odometer, battery, airbag, oil lamp, seat belt and e-brake. The other lights won't come on.
- The open door sounds off six times then stops.
- I did NOT smell anything burning like oil or see any dark smoke. I also saw NO leaks, I checked the oil and fluids, everything was normal.
- I had a full tank of gas and had JUST picked it up from having the throttle body/MAF sensor and IAC cleaned the day before.
- The battery, alternator, PCV Valve and main fuse were all new. The engine also seems to move. The car was driving fine before this happened.
