2002 Kia Optima
I have a 2002 Kia Optima and the reverse is out. It also shifts hard at high rpms. I took it to Auto Zone and got the codes ran and it is the shift solenoids. I can't remember the codes off hand, but I was wanting some feedback on what this may cost or how much work it involves. It started one day when I rinsed off my engine and when I left the car wash, it started acting up.
91eagletsi-06optima
Wishing kia had seamless shift transmissions
These symptoms don't sound good sir, if the shift solenoids are ok umm.. Nobody likes to hear a they need a tranny, when the time comes just replace dont rebuild.​
The friction material for a auto transmission can be measured in mm, one major slip at high rpm can be devastating to the friction material​
Keep us posted and good luck sir, did you check your fluid latley? If its off or on the tip of the stick you cooked it​
