Is there a way to give a false code to the computer to show o2 sensor to turn off check engine light?
2000 Sportage 4x4 , 1998 Saturn SC2
Are removing the Cat ? I would not use one on the Upstream O2, because the ECU needs that data. I had a 94 Camaro that I removed that Cat and sent the PCM to someone for re-programming as the downstream O2 monitors the Cat. I have not used one on the Sportage.
