Will start off with what happened & what I have done, & hope someone can give me some ideas on what to do next.
Couple days ago, filled up the gas tank & started heading home. while climbing up a hill, the Sporty started losing power & quit when it got to the top of the hill. It turns over fine, has spark, wasn't getting fuel. So checked fuel pump fuse & relay, both good. Dragged it home, went & bought new fuel pump, strainer & filter. Installed new pump, yadda yadda, go to crank it back up & nadda. Turns over, Has fire, no fuel. Take pump back out & hook it straight to the battery to make sure pump works before going & cussing out parts store, sure enough, pump works. Next I took a multi meter & checked to see if current is going back to the pump. With key on, probing the plug that goes to the pump, showed 12.74 volts. so, it is getting power. Gauge sender also showed voltage. Next took off grounds, cleaned contacts, torqued them back down tight, did continuity check from ground wires straight to the battery, no problems found. Yank out the fuel pump relay, test it, works fine. Yank out the Main relay, test it, works fine. noticed the main fuse (15 amp in engine compartment fuse block) was popped. replaced it, turn on ignition & POP it blows out. take fuse block apart, clean every contact in it, re-assemble, put in new fuse & POP, same thing, main fuse blows out. I removed the Main relay, replaced main fuse, ignition on, fuse holds. the moment you put relay in, fuse pops ( not just a little pop, the bright blue spark & almost launch the fuse out of the box type pop)
So, wondering if anyone has a suggestion as to where I should look first for the short before i go ripping through wiring. Not completely understanding why if I have voltage at the pump, the pump will not engage.
Up till this, the Sporty ran perfect, no codes, & purred like a kitten.
