i need some help.does the 2001 kia sephia use r134a refrigerent,the nosles on the high and low valve look diff.do you need to screw in something.
[/URL] Uploaded with ImageShack.us[/IMG]
the low side without the cap on
i tried to google it,but couldnt find much
also is there a way to clean all the greese off the engine bay
Your spectra does use r134 freon. The low side and high side are different only in size so you can't mix them up when hooking up a a/c machine.
