1 - 1 of 1 Posts
Hi.Im new to the Sportage.Never worked on them.My friends Sportage idles rough but smooths out around 1500 rpm.It has 77k miles..Automatic 4X4.I cleaned the IAC valve and fixed a few vacuum leaks but still idles rough..She had the plugs and wires changed but still idles bad.Do you think the next step is checking the compression?The car still has power.Tommorrow im going to try and fix the trans lines that are leaking..Seems to be leaking at the rubber hoses.As far as i can tell those lines clamp on the metal ones.Is that correct?Thanks!
1 - 1 of 1 Posts
