I have codes p0135,p0141. Both heater ciruit malfunctions.
I removed the fuses and Ohmed the ciruit side of the fuse thru the heaters on both front and rear to pins 30 (rear) and 31 (front) at 211 connecter at the ecu,ecm..whatever they call it on that.Both pins have 3.5 ohms indicating a clean circuit,considering the heater itself at 2 to 4 ohms.Id like to know what pins connect those pins to ground when you start the engine,my rear heater has no ground when running..Both the front grounds at pin 37 and heater operates.I searched kiatech with no luck...ive tried swapping ecu's.pin 28 on 211 has a good ground to b-.
thanks for your time
