The check engine light just came on and I went to Auto Zone to check the codes for free. Codes P0171 System to Lean (Bank 1) & P0455 (Evap) Emission System Leak "Large". I also noticed that when I push the over drive button it says (OD Off) on the dash. Before, the OD light would come on but with out the "Off" light on. The car appears to be running fine when up to speed but a little rough at idle. Any ideas??
well i get the first code p0171 on my car but that is because i have a header without the pre-cat on. im suspecting a problem with either and 02 sensor or teh precat.
with the other code i saw it has to do with a exhaust leak maybe in the cat. and thats why the 1st code is comming on.
the od light should always come on when you hit the button.
you might not smell an exhaust leak you might just be able to hear it. and yes when you hit that little button on the gear shifter it shuts off the overdrive gear ratio and the light illuminates to tell you that you shut it off. this is what is supposed to happen.
on the bumper lol i got one as you can see. its got a ding on the lower part of it. and will need paint. it has green but its a bit chipped id let go of it for say 50 + shipping. stock bumper
thats if you want a stock bumper i might be in the very near future be selling the bumper you see in my pic.
