It could be a vacuum leak or a sticky Idle Air Control valve (IAC or ISC).Sure could. Did it just start one day? Do you hear anything out of the ordinary?
Have you tried the idle adjustment screw? Does the engine start differently?
The Throttle Stop Screw is factory set and must not be adjusted. Any adjustment will negatively affect the engine performance.
