Driving home from work it just went dead. No fuel.. no spark. . Check all fuses relays. . Replaced tcm from salvage yards timing is correct. . What else can I do. .
Ok, based on the codes, you have anen or a short in the wiring from the ECM to the TCM. You'll need to do some electrical work to find where the issue is.
Going to look again in the morning. . But I feel like I've looked at everything possible. . Wires between ecm and tcm is that under the dash or hood
I found this information online, I hope it can help you.
Kia Sephia's OBD2 code P1800:
Engine torque signal malfunction
Threshold Value ~ Circuit continuity: Open or shorted
Enable Conditions ~ NA
Time Requirements ~ Continuous
Related Items
1) Open between TCM (C221-41) and ECM (C254-68).
2) Short to B+ or GND between C221-41 and C254-68.
Step by Step inspection, with YES / NO Action:
With ignition off, disconnect C254 from ECM and C221 from TCM.
Measure resistance between C221-41 and C254-68 (less than 1 ohm).
Is resistance as specified?
YES = Go to step 2.
NO = Locate source of open or high resistance and repair as necessary.
Measure resistance between C254-68 and GND (infinite resistance).
YES = Go to step 3.
NO = Locate source of short to GND and repair as necessary.
Turn ignition on and measure voltage at C254-68 (0v).
Is voltage as specified?
YES = thoroughly check for loose, bent or corroded terminals in circuit then go to step 4.
NO = Locate source of short to B+ and repair as necessary.
Clear codes and return vehicle to original condition. Verify any repairs by driving vehicle with Scanner connected to OBD-II connector for monitoring pending codes (refer to scanner's owners manual).
Kind Regards.
By the way, this thread got Lost, because it was posted in the first gen Sephia's forum, while it belongs to the second gen Sephia.
