Kia Sephia 2000
Steering column cover (2 piece) bottom half has three screws to secure on the steering column. The metal screw is located closest to the back, not the two front screws that has different type of threads, is missing. According to the parts catalogue, the part number is K998330512. Does anyone knows the metal screw size and its length so I can get it at a local hardware store?
Kia Sephia 2000
Discussion Starter #2
Update:
I found a compatible bolt/screw that goes on the steering wheel column cover in the back. It is a 5mm bolt using 8mm socket. However, due to the size of the 8mm socket is too large to go through the hole of the steering wheel cover, I was abled to get another 5mm metal thread bolt/screw using the Hex head. The measurement of the hex head is 5/32 inch, using a hex key, Because of the smal size of the hex head through the hole, I used a washer on the 5mm thread to prevent the bolt going in too deep,passing through the plastic steering wheel column cover. It works now fine. Thanks to all for reading this thread.
