Hello,I have a Kia sephia year 2000,the car is missing at hi way speeds,seems to be sluggish, that sad thing is I'm not receiving no problem codes! Her is what I have done so far, new plugs twice,new wires,new coils,new timing belt,fuel filter,throttle position sensor,cleaned idle air control,cleaned mas sensor,done compression test.it doesn't do it all the time,seems worse when it warms up and in over drive,I removed the crank position sensor and cam sensor and checked for cracks,ohmed the crank sensor and it was in specs,not sure how to ohm the cam sensor,also pulled the catalatic converters,the problem is intermittent,don't really have the money to start buying parts until I find it, I bought a fuel injector to try on each cylinder, waiting on it to be delivered,? Any help would be greatly appreciated!!
Thanks Chris
Thanks Chris
